Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much HP on my new 383 engine, plus some questions for the pros!
Old 02-08-2003, 04:52 PM
The Vandal's Avatar
The Vandal The Vandal is offline
Engine Tech Addict
Post
Tq 427@3500 HP 340@4500
Must use at least 21 lbs.hr injectors.
80 mm TB can flow 1189 cfm (just so you know)
Recommended cam is 219/220 .455/.461
Blower Added:
Tq 554@5000 HP 572@6000
at least 45 lbs/hr injectors
This was using the recommended 252/264 .575/.609 cam.
EXTREMELY low idle vacuum. VERY rough idle.
I vote you spray it as well.........
The Vandal
