[quote]Originally posted by The Vandal:
<strong>Tq 427@3500 HP 340@4500
Must use at least 21 lbs.hr injectors.
80 mm TB can flow 1189 cfm (just so you know)
Recommended cam is 219/220 .455/.461
Blower Added:
Tq 554@5000 HP 572@6000
at least 45 lbs/hr injectors
This was using the recommended 252/264 .575/.609 cam.
EXTREMELY low idle vacuum. VERY rough idle.
I vote you spray it as well.........
The Vandal</strong><hr></blockquote>
Vandal what program did you use to figure this out?
Also if I upgrade to a bigger SC and run 15psi of boost what would the numbers be?
Also, cam quoted is the biggest I can run and still pass smog with a good idle too
Ken
