how much hp should it make? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-08-2014, 12:54 PM
Project89's Avatar
looks like the heads will be here on friday, i also said hell with it and ordered up a set of 10cc dished pistons ,with a .015 shim type gasket i will have 9.1-1 compression with the 64cc heads
next week i will order up a set of bushed rods , head studs and the remainder of the head hardware i need to finish assembling the heads , along with a push rod lenght tool
  #32 (permalink)
Old 01-11-2014, 06:29 PM
Project89's Avatar
heads got delayed till monday , and pistons wont be here till wensday
i kinda wish i wasnt building this engine , as i just did an engine swap in a dodge ram pickup yesterday and today, and got a free 8L v10 engine, if i wasnt so deep into this 355 already id go buy the viper intake , swap the cam and drop the v10 in the car , and then make new turbo manifolds for that
  #33 (permalink)
Old 01-13-2014, 01:15 PM
Project89's Avatar
heads got here a few minutes ago
  #34 (permalink)
Old 01-13-2014, 09:25 PM
vinniekq2's Avatar
get busy,clean them and bolts them on.
  #35 (permalink)
Old 01-13-2014, 09:30 PM
Project89's Avatar
cant yet my pistons wont be here till wensday
  #36 (permalink)
Old 01-13-2014, 09:42 PM
vinniekq2's Avatar
ok...not much fun putting pistons in from the bottom,lol.
  #37 (permalink)
Old 01-14-2014, 12:00 AM
Project89's Avatar
so ive been doing more in depth research now that i have the heads in my hands, taking measurements and comparing these heads to a big brand name head that they are rumored to be copys of
these heads are infact dart pro 1 platinum copys , and can be ported out to flow well over 300cfm
  #38 (permalink)
Old 01-14-2014, 06:36 AM
vinniekq2's Avatar
Thats a decent number.Can I smell 1K hp?
  #39 (permalink)
Old 01-14-2014, 03:32 PM
Project89's Avatar
i didnt exactly have the right gaskets on hand , but this is with a standard rebuilders gasket
lol those heads and valve covers will dwarf a tpi intake
theres just enough meat on the tpi intake to seal up the port but not by much
will it work with a standard sbc intake ...... u would have to check each intake to see if it would seal, the tpi does seal but i wouldnt use it , i would deffinatly get a votec tpi base or other vortec or raised runner intake
im going to send back my standard hsr for a vortec hsr , though im still debating on a single plane efi and elbow or 4bbl tb setup
  #40 (permalink)
Old 01-15-2014, 12:28 PM
Project89's Avatar
yay new pistons showed up almost time to get the motor 100% back together
hyper piston with 10cc dish , i need to knock off the sharp corners were the inner dish meets the valve reliefs as they look like a prime edge for a hotspot to develop
What are you doing to make it? dinger Off-Topic 14 05-12-2009 11:36 AM
can you make these better? 79C10 Hot Rod Art 6 01-02-2008 08:41 AM
Make your own? bigedd396 Engine 14 08-22-2005 05:49 AM
did they make or can you make chevellenut Suspension - Brakes - Steering 4 12-22-2003 01:45 PM
