How much hp will this boat setup make? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2012, 06:29 PM
Already got everything on order for my boat motor. just curious what you guys think I should expect.
460 ford bored .060
4.5 scat crank
10.2:1 compression
cam: Solid flat tappet 258 dur at .050, .615 lift
roller rockers
Super Cobra Jet heads
Tunnel ram with 600 holleys
Old 01-20-2012, 08:56 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Jet boat? That's the only thing that would take that much RPM.
That much cam duration is dry-exhaust only. Otherwise you'll end up with raw water getting thrown around the valves when its hot. That much duration is also jet-only. Put a prop behind it and you may not even get up on plane. You also need your cruise RPM to be above the torque curve on prop boats.
Also consider that its rare to find a marina with premium fuel.
Old 01-21-2012, 09:02 AM
bondo's Avatar
Ayuh,... Curtis is Right on,...
More info is needed, as a Jetboat ain't nowhere near the same as a propped boat...
'n, generally speakin', the 460 Ford, or any Ford ain't a very popular Boat motor...
Matter of fact, Ford has been Out of the marine motor business for many Years now....
Old 01-21-2012, 12:10 PM
Haha sorry. Yeah it is goin in my jet. 460's are actually pretty often used in jets too.
Old 01-21-2012, 12:20 PM
curtis73's Avatar
Wiki Edits: 16
Ok, good. Lots of times on prop boat forums guys post about getting 500 hp from their 350 and we have to school 'em
I don't know how much those heads flow. You have any flow numbers?
Jet Boat Chris1962 Introduce Yourself 2 04-05-2011 10:25 PM
ice boat tutorfetch Introduce Yourself 6 12-19-2010 01:51 PM
help with my boat please jrm123180 Engine 34 06-29-2007 07:47 PM
cool 100 ++ MPH boat blown boat video Infomaniac Engine 12 11-24-2003 08:08 AM
my first boat 71montebbc Body - Exterior 3 03-05-2003 04:06 PM
