Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much hp will I have
Old 03-06-2012, 10:38 PM
southshore30 southshore30 is offline
Watch out for those Vortec heads if you go any higher lift! Make sure you have your machinist check retainer to seal clearance if you go with a bigger cam. I have a similar setup but am using the Comp xe4262x 4X4 cam. Just finished putting it together and have not run it yet. You may want a slightly larger carb too if you go with a bigger cam. Not saying mine is the perfect setup. I have the 906 Vortecs, flat tops w/4 valve reliefs so its 9.7:1 per my machinist with the gasket I used and am running a mechanical secondary 650 Holley. 300+ HP expected
