Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much hp will I have
Old 03-07-2012, 11:24 AM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Senior Curmudgeon
Wiki Edits: 326
That ES1014R camshaft closes the intake at 19 degrees ABDC and will result in a dynamic compression ratio of 9.54:1 if you truly do have a static compression ratio of 10.10:1. You'll have to run it on race gas or alcohol to keep it from detonating.
I'm going to list two cams, although there are dozens that would work for you.
Isky 270/280 MEGA Hydraulic, part no. 201271/281-12. Good all-around performance, GOOD IDLE and vacuum. 3.70-4.11 rear axle ratio advised. 9.50-10.50 static compression ratio advised. Computer compatible with stage 1 or stage 2 chip. Stock converter. 2200-6500 effective rpm range. 0.465"/0.485" valve lift, 221/232 duration @0.050". 112 lobe separation angle.
Isky 270 MEGA hydraulic, part no. 201271. Excellent mid-range performance. FAIR IDLE, stock converter. 9.00-10.50 static compression ratio advised. 3.70-4.11 rear axle ratio advised. Up to 650 CFM carb. 2000-6200 effective rpm range. 0.465"/0.465" valve lift, 221/221 duration @0.050". 108 lobe separation angle.
