How much hp will my 350 have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2012, 08:02 PM
I have a 350 4 bolt main bored 60 over with Vortec heads 12258060, stock bottom end with rv cam Enginetech es1014r, headers, dual flowmaster exhaust, holley 650 carb, flat top pistons with 10.1.1 compression
Old 02-22-2012, 10:10 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Give us the cam specs not just the number. I can't find the heads you spec, but assuming they're 64cc I come up with 9.76 c.r., flat pistons with valve reliefs.
Semper Fi
Old 02-23-2012, 05:12 AM
I meant Vortec 12558060 and they are 64cc,
This is an Eginetech ES1014R cam
__________INT.__EXH.
.050 Dur___204___214
SAE Dur____276___288
Val lift_____420___443
Old 02-23-2012, 06:33 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by TDMoss
stock bottom end
This probably means stock-type pistons with the circular dish and 4 valve reliefs, that pour out to somewhere around 11-13 cc's. If whoever bored the motor wasn't paying attention, they may have installed "rebuilder pistons" with a compression height of 1.540", instead of the correct 1.560" CH.
So, let's try to guess (that's all this will be, a guess) what the SCR will be.
4.060" bore with 3.480" stroke yields 738.3 cc's.
12558060 (casting 12558062) chambers are ~64 cc's.
Assuming the piston is down in the bore 0.045", the piston deck height volume will be 9.5 cc's.
We'll guess ~12 cc's for the piston crowns.....
and 9 cc's for a composition head gasket at 0.040" compressed.
All 5 values total 822.8 cc's
Dropping out the cylinder volume gives us 84.5 cc's
Dividing 822.8 by 84.5 yields an SCR of 9.73:1
The squish will measure out at about 0.085", so effectively, there will be no squish action in this motor.
The cam you have used closes the intake valve at 19* ABDC @0.050" tappet lift and the KB calculator tells me that the DCR will be 9.22:1. If conventional 1.560" pistons were used, the DCR will be even higher.
I don't think it's going to last long enough to make any hp if the above figures are anywhere near correct unless you're operating it on race fuel.
Old 02-23-2012, 07:28 AM
I will be running on 93 octane... So what power range do u think I will be in?
Old 02-23-2012, 01:28 PM
Wiki Edits: 326
I don't think you're paying attention.
You won't be in any power range. You'll be in a cab getting a ride home because detonation has cracked the crowns off all the pistons.
Old 02-23-2012, 05:04 PM
Hotrod 80's Avatar
300 At the tires
