How much lower will the frame lower once the real motor is installed ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 11:13 AM
Tonythefish's Avatar
Last journal entry: final pics
I am using a plastic mock up motor and th350 case to mock up the entire front end of the car ( 32 ) .. the entire setup is ~50 lbs ... What is your experience the frame will lower in inches , when the heavy SBC and trans is installed ?
Old 02-05-2007, 12:29 PM
It will depend on the spring you used ... but my 32 steel Roadster ( with steel fenders ... ) dropped about 1 and 1/2 at the beginning and settled on down to almost 2 inches after a few thousand miles. I have a TCI front spring. My car has aluminum heads, intake and water pump.
I would not want it any lower ... every now and then the front tires will rub the fender brace ...
Old 02-05-2007, 01:42 PM
I used Speedways 4 bar complete front end
Old 02-05-2007, 04:14 PM
I would think they would be close to the same ...
But other factors play into the equation ...
1) how far back you set the engine ...
2) the radiator ... 2 row, 3 row, 4 row ... aluminum
3) the cross member ... mine is set as deep as possible ...
4) headers or manifolds ...
5) aluminum heads ... intakes and such
6) A/C ...
Cantilever system for air bags 53LEDSLED Suspension - Brakes - Steering 17 12-05-2004 03:26 PM
Frame Insulator Lower zeeman19 Suspension - Brakes - Steering 1 09-11-2004 03:53 AM
Frame Insulator Lower Need help FAST zeeman19 General Rodding Tech 3 09-10-2004 06:57 AM
Frame Insulator Lower zeeman19 Body - Exterior 0 09-09-2004 08:13 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
