Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much lower will the frame lower once the real motor is installed ?
Old 02-05-2007, 12:29 PM
Deuce Deuce is offline
It will depend on the spring you used ... but my 32 steel Roadster ( with steel fenders ... ) dropped about 1 and 1/2 at the beginning and settled on down to almost 2 inches after a few thousand miles. I have a TCI front spring. My car has aluminum heads, intake and water pump.
I would not want it any lower ... every now and then the front tires will rub the fender brace ...
