how much is to much reducer - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2009, 09:44 PM
maybe my problem is over reducing could this be causing my solvent pop? I was shooting cc with 10% reducer and having some orange peel.so I reduced to 20% goes on like glass but I think I'm getting solvent pop. my shop temp is around 70 d I was spraying with mid temp reducer/activator sooo i'm wondering now what would happen if I went with slow activator and fast reducer? thanks for any and all info.....dan.
Old 12-15-2009, 10:02 PM
Yes, yes, YES, YES that could be your problem. What are the manufacturers recommendation?
If you used a "slower" reducer so the top would "say open" longer for the solvent to flash off my be a fix too.
Old 12-16-2009, 07:02 AM
thanks manufacture recommends 10%. I have heard of painters shooting up to 50% on final coat. thanks
Old 12-16-2009, 08:57 AM
Honestly 50% is WAY too much and can cause all kinds of problems. People do all kinds of things I mean some cops steal drugs from guys they arrest, it don't mean they are doing a good job!
Setting up the gun properly is the key (the right choice of equipment and a quality air supply is paramount of course) to getting good atomization and a smooth finish.
Old 12-16-2009, 11:01 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Work on the gun settings as most material will layout wet and slick with the proper settings..Rule of thumb is no more than 10% reducer if needed at all..Now saying that I use one clear that is mixed 4:1:1 for all overs..
Sam
Old 12-17-2009, 03:17 PM
thanks for all the info guys. I do still have one q? If I shoot the clear with a shop temp of 72 degrees, will it help me to use a slow activator and a fast reducer? I was thinking the reducer would dry up before the activator skimmed over on top. but I don't know thanks.
Old 12-18-2009, 12:00 AM
milo's Avatar
point on positive
If the clear it's self is to cold it will affect it's viscosity.
The idea is to use the right speed/temp reducer and just enough to let it flow through the gun ..
There were some good threads about viscosity around here some where ...
Make sure your material it'self is also up to temp..
Paint Viscosity Follow Up
I always get orange peel! I hate orange peel!
**=> http://www.a2zautoforums.com/showthr...ight=Viscosity
Reducer question Wraith Body - Exterior 8 09-03-2009 10:41 AM
Urethane Clearcoat Reducer DGW Body - Exterior 44 11-15-2007 10:13 AM
Clear coat reducer? magnoman Body - Exterior 8 07-01-2007 04:42 PM
need help with a 12 v to 6 v reducer oldguy829 Electrical 32 08-21-2006 06:02 PM
Where to find AcrylicEnamel Reducer and thinner on the net? lexicon1 Body - Exterior 1 04-11-2006 06:51 AM
