how much oil for a 79 SBC 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2005, 08:33 PM
montea's Avatar
tryn to learn
i just put a 79 350 into my 82 grand prix but the dipstick was on the wrong side runing into the manifold meaning i need a new one and i found a universal one that will work but you need to adjust it for the engine and i have no oil in the engine currently to compare with the new dip stick so i gota put in the correct amount of oil and adjust the stick from there.
does anyone know the correct amount? i heard 5 quarts is that right?. but is that just quarts or US quarts? reason i ask about that is when i convert that to litre that us Canadians use, its a 1 litre(bottle) differnce.
Thank you
Old 06-21-2005, 08:46 PM
GothRod87
5 quarts is us for sure man...i say fill er up and just adjust as needed..im thing scraching a line with a file will do it...good luck,
Brandon
Old 06-21-2005, 09:31 PM
montea's Avatar
tryn to learn
ok thanks!
Old 06-21-2005, 09:43 PM
poncho62's Avatar
Wiki Edits: 5
4 1/2 litres with a PH30 filter
5 litres with a PH13
Old 06-21-2005, 10:27 PM
montea's Avatar
tryn to learn
oh right on poncho!
Old 06-22-2005, 12:00 AM
Don't forget to run the motor long enough to fill the oil filter up before you mark the stick.
Old 06-26-2005, 11:31 AM
Tazz
instead of doing that...
fill up the oil filter then install it and then add the oil and then start the engine....I always fill up the oil filter before installing it then add 4+ quarts to the fill line of the stock fill tube...then remove the stock fill tube and mark your aftermarket fill tuibe. You can bend the stock fill tube to miss your exhaust...your going to replace it anyway!!.
Tazz
Rat Rods Rule!.
Oil leak in 350 Chevy Ed Baltera Engine 18 07-29-2012 12:24 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
Correct Oil Pressure for SBC 350 Houman SS '70 Engine 13 03-16-2005 03:01 PM
Help 350 rocket bad timing chain & low oil pressure? 71oldsmann Engine 2 03-15-2005 12:45 AM
Rear of engine oil leak 350 western star Engine 5 07-13-2004 04:32 AM
