how much oil can the distributor gasket leak on a sbc? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2011, 10:42 AM
ok i know i always end up rambling so i'm going to try and control myself this time. had a pretty good oil leak come up yesterday after driving at 4000 rpm down the highway going to work (th350 trans) it leaked about a quarter quart of oil in 20 miles. i figured that i had blown the rear intake seal because of too much crankcase pressure. but today as i start tearing it apart, i find that when i installed the distributor that i kinked the gasket so it wasn't sitting properly. the question is, do you guys think that the distributor would leak that much or should i go ahead and pull the intake off and re seal it while i'm almost there? i should probably just do both so i don't have to take everything off again if i fail. but just looking for some other opinions. thanks guys
Old 05-30-2011, 10:59 AM
well after staring at it for about a minute i decided to fix it once lol so i went ahead and pulled the intake off to make sure i don't have to do it all again
Old 05-30-2011, 11:23 AM
Sounds like a good move.
Old 05-30-2011, 11:47 AM
DENCOUCH's Avatar
back in that area on a sbc, you will find a small tapped hole for the oil pressure sending unit. You may give that some attention as well. I have heard that sometimes others have forgotten to tighten or seal the sending unit... others have relocated it & left it out completely during a rebuild.
...just sayin'.
GM 3.8L intake gasket leak GMR Engine 2 12-30-2010 06:50 PM
1pc. oil pan gasket leak 19nova69 Engine 8 07-14-2010 06:58 PM
Head gasket leak ? truckboy61 Engine 3 10-08-2009 09:02 PM
Head gasket leak ? truckboy61 Engine 2 10-08-2009 06:18 PM
V6 head gasket oil leak 1935 Ford Steve Engine 2 06-15-2006 11:31 AM
