How much oil does TH350 hold? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2005, 06:18 PM
Hi guys, Kiwi newbie V8 learner chick here - about to fill up my newly recond TH350. How much tranny oil should I put in?
Old 12-10-2005, 06:28 PM
That will depend on how large the cooler and converter are. Was the unit completely dry, or has it been filled with oil before? Here is the sequence that I suggest:
1. Fill with 6-7 quarts.
2. Start engine.
3. While holding the brake so that the wheels DO NOT turn, shift through all of the gears slowly- 10 seconds each gear.
4. Put it in park and continue filling until it reads full on the stick.
Old 12-10-2005, 06:36 PM
Kiwichevgal,
Great to have you on the board!
If you are replacing the torque converter and filling the transmission then it will take at least 12 quarts or just under 12 liters. I put in six quarts with the engine NOT running. Then start the engine letting the engine idle and shift the trans through the gears. I drop the lever to Low range then I put it into Drive and then Reverse. Then back to Park. Then four more quarts this time while the engine is still running. Then shift the gear lever again. Back in Park I now check the level using the dip stick. Keep adding fluid until the level reaches the full mark on the stick.
Have fun
Scholman
Old 12-10-2005, 11:00 PM
Thanks dudes - your input is much appreciated and helpful!! Just another step closer to getting the motor back into action. No doubt I will become a regular to this bulletin board and will be looking to all you fabulous blokes again for valuable assistance. Cheers from 'downunder'!!
Old 12-11-2005, 09:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since we do not know what size converter you are using or if you have a deep pan on the trans.....the total capacity can change from application to application
I suggest at least 4 quarts added before the engine is started, If a deep aluminum pan is used add 5 quarts Then add 5 more quarts . Then shift the trans through all gears with the foot on the brakes.
Re-check the fluid level in park and add fluid till the level is at the "add" mark.
Old 12-11-2005, 10:26 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You need to put 3-4 quarts into the torque converter before installing it on the transmission. Dry start up.
Mobil 1 synthetic.
Old 12-12-2005, 09:58 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
TCI Recommends one quart inthe converter to start. A T-350 with a stock pan holds 4 quarts according to the charts at the site below. A 10" converter holds 3 quarts, 11", 3.5 quarts.
Transmission Capacities
Who makes the best oil??? classic_chevy_guy Engine 28 02-21-2013 08:04 PM
Do NOT buy AC Delco Duraguard Oil Filters!!! indy_85stariones Engine 74 07-06-2009 02:19 AM
oil pressure sending unit? Brian Morency Engine 2 07-21-2004 03:43 PM
No oil pressure cleancut Engine 12 04-30-2004 10:35 AM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
