how much oil for a fluid change E4OD ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2007, 09:55 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Please help,
how many quarts does a regular fluid and filter change takes an E4OD from a 1997 expedition 4x4 ?
The manual says 15 but must be after a full rebuild, I'm not taking it appart just a regular service.
Thanks.
Augusto.
Old 05-01-2007, 08:14 AM
About 7 quarts. Unless you drain the torque converter, then it's about 15 quarts.
Old 05-01-2007, 02:09 PM
Augusto's Avatar
do ford converters have a drain plug? how reliable is the drill and blind rivet method to drain the converter?
Augusto.
Old 05-02-2007, 07:59 AM
how much fluid
This vehicle has a drain plug, but not on the back of the converter.
There will be a black plug on the bottom of the bellhousing, pull it off, look up,rotate the motor until you see the drain plug.
Old 05-02-2007, 12:51 PM
Augusto's Avatar
thanks Briscoe
Augusto.
Old 05-02-2007, 01:00 PM
how much fliud
My pleasure, Augusto.
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
low engine pressure molevolent_creations Engine 14 12-24-2005 08:49 PM
Beware of those Quick Oil Change Shops! Centerline Hotrodders' Lounge 14 10-10-2003 01:27 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
Transmission fluid in motor oil? Psydex Transmission - Rearend 2 08-13-2002 03:29 AM
