Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much paint do I buy?
Old 01-24-2013, 01:08 PM
Dayo5's Avatar
Dayo5 Dayo5 is offline
Thanks so much for your inputs!
This is a First Time project for me. I am open to all suggestions! The car will not be completely down to bare metal, just the spots where I am grinding the rust down and off. I read some posts that you should epoxy prime first then do the Filler work. Are you saying that is only if the car is totally down to bare metal?
I was going to scuff the car, grind off the rust, epoxy prime, filler, the epoxy prime over that. Are you suggesting that I do the filler first then cover in epoxy prime?
I appreciate your time and experience.
