Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much paint do I buy?
Old 01-24-2013, 04:51 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
You never what any paint under your body filler. Epoxy primer is ok if it is bare metal with epoxy primer on it only. Best is to grind to metal anywhere you need to do any filling. well out past where you need to fill then feather your old paint, epoxy prime, let dry then scuff and then do your filler work.
