Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much paint do I buy?
Old 01-25-2013, 07:27 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Using an electric palm sander is OK....however...what ever you sand will not end up being straight. If you use a 4 inch palm sander, make sure to keep it as flat on the panel as possible and you will need to hand sand corners creases and edges. This will be alright for initial priming....When you sand for paint I would recommend hand sanding with a finer grit on a block using a guide coat to find your high and low spots.
Hope this helps.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
Dayo5 (01-25-2013)
