How Much Paint Do I Need? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 07:45 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I am ready to purchase the base and clear for my 1954 Chevy truck project and want to ensure I have enough paint for the project plus have a little left over for future needs.
The truck has been stripped and primered on all surfaces, inside and out. The plan is to paint everything the same color. The color will be a medium silver.
Will one gallon of base and one gallon of clear be enough?
Picts are in my photo gallery.
Old 04-04-2006, 07:49 AM
Wiki Edits: 31
it depends on how many coats, what kind of paint gun your going to shoot with ( HVLP or not ) and how well your color covers, talk to the paint store you get the paint from, and what your doing, they should be able to give you a good estimate.
Old 04-04-2006, 07:55 AM
Houston54's Avatar
I will be using my HVLP gun. I am hoping someone who has painted one of these trucks, or similar, before can give me a good "feel" for the material needs based on the silver color I noted. The paint store has said a gallon set up would enough but I am not too confident in their unseen appraisal of the situation. There are many surfaces on this truck that need paint - bed inside and out, doors, interior, cab, fenders, hood, tailgate. Many of these panels have two or more sides that will need coverage. Has anyone else painted a complete truck? Thanks though.
Old 04-04-2006, 08:41 AM
302 Z28's Avatar
A gallon is going to give you two gallons ready to spray if the mix is 1-1. Consider a minimum of three good coats of base. On my full fendered 34 Ford I am planning on two gallons of unreduced DBC. I already have purchased one gallon of DBC to paint the smaller items like under deck lid, inside of doors, underside of hood panels, door hinges, deck lid hinges, dash, interior moldings, and grill shell. Just painting those items has led me to realize that one gallon of unreduced will not be enough. It is going to take two gallons of unreduced. I will probably have a gallon or so of reduced DBC left over when I am finished, but that is way better than running short. FWIW my mix is $392 a gallon with a gallon of DT885 reducer being $30. This is not even counting the clear and activator.
Vince
Old 04-04-2006, 10:58 AM
as the other gentleman said 1 gallon will give you 2 spayable, but depends on the grade of paint. ppg will give you 2 a good 2 gallons sprayable, but if you go with ppg's cheaper paint omni it does not cover very well. it takes more coats and more paint.
Old 04-04-2006, 04:23 PM
I think a gallon of base will be a bit short if doing jambs, inside bed, under hood, firewall ect., even in an upper line which coverage is usually better. I usually figure just for the outside of an average size vehicle around 3 quarts of base, mixed 1 to 1 (Giving 6 quarts sprayable) even though my hvlp is pretty good at not wasting paint and may take a little less. I want to say around a gallon and half of unreduced base with a 1:1 ratio, and if it is a 4:1 clear 2 gallons of that. If you dip your paint stick in the paint when you get it, you can sort of tell how its going to cover, if on the edges of the stick it looks really transparent and you can easily see the paint stick color through, That color is likely going to be a poor covering one and probably has a lot of toners in the formula. I wouldn't think silver would cover too bad. If you are painting the insides first before and reassembling and then shooting the outside, you can kind of guage how many coats its taking for coverage and figure the amount you will need when you get to the outside, and you can put maybe only two coats of clear inside the bed and other areas you won't be buffing. It normally takes me about 1 to 1 1/2 quarts of reduced base to put a coat on the outside of an average size vehicle. Maybe multiply 1.5 times the number of coats it took to achieve coverage on the interior parts and figure that amount of reduced base (or divide that number by 2 for amount of unreduced base if a 1:1 base is used)for the outside with a little saftey net built in. Then if you feel you will be short, by the amount of base you need and mix it in with your left over base to shoot the outside.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 01:33 PM
Need advice on a paint job tishmomo Body - Exterior 36 01-15-2008 12:19 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 11:39 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 10:26 PM
This is interesting. Temporary peel off paint. kenseth17 Body - Exterior 5 08-11-2005 10:41 PM
