-   -   how much paint for frame (http://www.hotrodders.com/forum/how-much-paint-frame-210606.html)
lamothe1 12-19-2011 11:51 AM
How much paint should I purchase to paint the frame of my í34 Ford after it's sandblasted. It's about 98 s.f. of area. Iím going to use polyurethane or would POR15 be more durable?
Irelands child 12-19-2011 12:34 PM
I originally painted my '31's chassis with DuPont Centari. I still have several ounces of ready to spray left of the quart. You do need to do a good prep, prime and clean first. As far as POR-15, do a search and you will find mixed emotions. Myself, don't care for the stuff. I ended up having my very nice Centari paint job blasted and then powder coated. Much more durable - and again, 'emotions' run high there as well. I'm happy with mine several years after being done as there are zero chips, dings or rusty spots.
lamothe1 12-20-2011 09:32 AM
Living in California we can no longer get DuPont Centari. I can get urethane and polyurethane which is mixed 4:1. I donít know if a quart would be enough Ė maybe I should try Ĺ gallon? When I used to paint a car with acrylic enamel by the time it was reduced you could paint a whole car. With polyurethane there isnít a reducer you just add a catalyst so it probably wonít go as far.
Old Fool 12-20-2011 10:01 AM
I'd use SPI Epoxy. Puchase a gallon kit, you will use it on the project, its one of the best 1st steps out there.
lamothe1 12-20-2011 03:45 PM
i was going to use SPI epoxy, but i want black gloss and they only have "semi-gloss"
Old Fool 12-20-2011 05:50 PM
I still suggest using the SPI epoxy, then shoot single stage black urethane over it for a top coat. I know doing it this way will cost more than using a single product,, but I truly feel the cost and effort is more than offset by the end product if offers.
