how much paint for a pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2010, 09:38 PM
im a first time painter and i getting close to ready to paint my 77 f150 pickup long box regular cab. im not painting inside the box and the inside of the cab, doors and hood are painted already. i want to use omni epoxy as a sealer i already have half a gallon of it. and the color is a bright pearl blue im using omni base i already have a half gallon of it. and ppg clear i have ahalf gallon of that too. can anybody give me an estimate on how much more supplies ill need i plan to buy extra but i dont want to buy alot extra that i probably wont use. my local paint supplier isnt very helpful and i will rather use a different supplier for my next project. and wont be using the omni or ppg paint anymore. thanks
Old 07-08-2010, 04:23 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
How much paint needed .
I had a body shop from '82 thru '85 and used catalyzed acrylic enamel back in the old days . It would take 1 gallon of paint plus reducer and catalyst to paint any full size car or pickup with three coats of paint. Be SURE to follow the manufacturers mixing recommendations on the paint can for best results . Do Not let the paint dry completely between coats for best flow and gloss . Use a good gun . Good luck.
Also , you may want to know that Speedway Motors has excellent acrylic urethane which I recently (Jan of 2010) used on my T-bucket .
Old 08-17-2010, 12:27 PM
What's the mixing ratio on that paint. how many sprayable quart would I need to lay down 3 layers of base and maybe 4 coats of clear and I don't want to risk running out?
Old 08-17-2010, 02:53 PM
39Hemi's Avatar
As a rough guide I would say 2 quarts sprayable for each coat, in other words for each coat with a one quart cup on the gun you will refill the gun once and have just a little left in the gun when you finish each coat.
Check your data sheets for mixing ratios for the paint you are using and you can figure out what you need.
Generally if you need to buy 3 quarts you might as well buy a gallon because it will be about the same money.
Four coats of clear sounds like a lot to me, especially if you are using a quality high solids clear. If you get too much film build you can have more problems with chipping down the road. Again read the tech sheet but unless it specifically calls out for more coats I don't think I would go past three, even if you plan to cut and buff.
Old 08-18-2010, 09:52 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
I'd like to reinforce everything said here . Exactly what I encountered in my career painting days . I prefer only two coats of clear .
what is the proper way to spray paint with a can? luckydevil Body - Exterior 19 01-07-2015 11:39 AM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-22-2007 12:32 AM
what color to paint? jum Body - Exterior 14 07-30-2006 01:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 01:18 PM
