how much paint will i need - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2010, 08:16 AM
i am doing a red bccc paint job on a 1966 gto hardtop. it is a color change so i have disassembled the car and am doing jambs and everything. how much paint will it take using nason paint? i picked up a gallon of paint plus reducers yesterday. will that be enough? i am using a hvlp gun w 1.4 tip.
since i plan to do it next 4th of july weekend when the stores are closed i am trying to head off potential problems. thanks
Old 06-30-2010, 08:25 AM
daoldbuick's Avatar
If your painting metallic, get more paint. Another gallon would be safe. Nason metallics take a lot of paint to cover, Ask me how I know.
Old 06-30-2010, 08:38 AM
no its not metallic. its straight gm victory red.
Old 06-30-2010, 02:58 PM
302 Z28's Avatar
If you want to be safe get two gallons, you then reduce it 1:1 to make 4 gallons spray-able. Yes it sounds like a lot of paint but if your doing jambs, under deck lid, inside doors ect you will need it, plus some left over for miscellaneous stuff.
Old 06-30-2010, 08:07 PM
Being a PPG Rep, I would suggest to get (2) two Gallons of paint....Remember to get the right reducer to match the weather conditions......In reguards to clear coat if you are just jamming parts out you can use spot clear to speed up the drying. I just finished up painting a 70 Chevelle w/ WA519F a very high metallic silver and it took almost 3 Gallons Non-Sprayable with black sealer. If you have any other questions feel free to ask....Roger
Old 06-30-2010, 09:15 PM
thanks guys. guess i need more. another question. what is the time limit on recoating this stuff? at what point do i need to sand before i can lay on another coat. i dont see anything in the instructions about that. it just says recoat anytime.
http://pc.dupont.com/dpc/en/US/html/...-cbasecoat.pdf
Old 06-30-2010, 09:53 PM
302 Z28's Avatar
You don't normally sand between the base coats unless you need to correct a problem, or you have gone way past the re-coat window. The PPG DBC that I used I waited about 40 minutes between coats.
Vince
paint information kimman Body - Exterior 13 06-02-2013 06:53 AM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 03:20 PM
what color to paint? jum Body - Exterior 14 07-30-2006 01:29 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 01:18 PM
