How much of a performance difference would I notice with a posi rear? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-07-2011, 08:39 PM
Hey tech I thought you were in Phoenix is North Carolina a suburb of Phoenix now?
  #17 (permalink)
Old 08-07-2011, 08:58 PM
life is a temporary assignment
Originally Posted by spinn
Multipling the torque from 2.76 gears to 3.73 is a nice choice, for those who can take cruising 65 at 3000rpm . That is with one wheel or two spinning.
When I had My Chevy Luv with a 9'' ford under it.. I had 4.56 gears and would run 60mph at 3000 rpm's.. Anything over that, And it would sound like something was going to give at any min..
And that was with 31'' tall tires..
  #18 (permalink)
Old 08-08-2011, 07:12 PM
techinspector1's Avatar
Wiki Edits: 326
Moved back here to live with my daughter for a while.
  #19 (permalink)
Old 08-08-2011, 07:20 PM
Tech
Good to see you back on the board. I missed your wit and wisdom.
  #20 (permalink)
Old 08-09-2011, 10:15 PM
Piland Triangle, Elroy, TX
Originally Posted by valtiel43
how much more performance would I notice?
Better broadies for sure!
  #21 (permalink)
Old 08-10-2011, 03:35 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Well judging from what I've heard a posi rear seems like it will really unleash the beast in this car.
Your missing what everyone is saying. If your not having traction problems a posi rearend will do nothing for you. Sure it will lite up both tires when u do burn out but thats not your problem. You need to have your gears matched to the compression and cam of the engine and stall of the converter. I have an 86 cutlass that had a 7.5" rear end with 2.41 gears. They sucked. Great for highway cruising and economy but that's it.
U asked what breaks on them. Last summer my posi unit failed at about 250whp.... then the small axles are an issue and the small pinion and then ring gear deflection... 7.5" ring gear sucks. Not worth putting money into . Look up my post on putting a Ford 8.8" rearend in my gbody. Cost me a total of about $400 and has posi and 3.73 gears and a huge ring gear and big axles.
  #22 (permalink)
Old 08-10-2011, 05:25 PM
And if you lift or downshift while driving into a turn at speed or in the rain, you will quickly learn the meaning of "lift-oversteer".
How much difference in engine performance.. DENCOUCH Engine 10 05-30-2009 06:20 PM
390 posi help with understanding difference? gwstang Transmission - Rearend 2 04-10-2005 09:01 PM
performance difference between #1405 and #1406 carbs? smlblcks10 Engine 5 12-08-2003 01:52 PM
289 vs. 302 Push Rods (Performance Difference?) white66coupe Engine 0 10-20-2003 02:51 PM
what is the gear difference on 10 & 12 posi 72 Z28 Transmission - Rearend 1 12-16-2002 06:29 PM
