By using Desktop Dyno 2000, I computed out 314 hp at 6000 RPM and 308 ft-lbs at 5000 RPM, this being a very generous output. I plugged in 9.5:1 CR, heads that flowed at 200 cfm (which is what stock BB Dodge flow unmolested), a 750 cfm carburetor, a dual plane manifold, headers w/ open exhaust, and that gargantuan cam you specified, and that's what came out. If your heads are truly stock 318 heads and you have stock 318 Compression, I doubt you would get over 280 hp. If you are breaking your tires loose at 20 mph in 3rd gear, you better get some new ones ASAP or find out what is wrong with your traction. If you are serious about making power with the 318 you need some good heads, dome pistons, a 600 carburetor (750 is too big by far) and a way, way smaller cam. That cam would be pretty radical for a 360 never mind a little 318. Sometimes parts that seem mild are what your engine really needs, rather than something too big, especially with the 318.
they aren't stock heads or pistons, i redid my entire motor with new parts (except block) bought the heads from jegs... http://www.jegs.com/cgi-bin/ncommerc...35&prmenbr=361 . I have had the machine shop do all the work.... after reading about turbos10 i'm going to tear it down and clean it though, i'm not sure if they did and i just put out alot to have it done.... the big carb is the one i pulled off the motor to start, it was a 900 holley so i did do something right. the tires are brand new and are 12.5 inches wide, i have a dana 60 with a lightweight aluminium spool and 4.11 gears.
If you are able to get the flow numbers from the heads and the compression ratio you are running, I would be able to give you a more "accurate guess" of your HP output. I doubt it would differ significantly from what I already gave you, but if you have aftermarket heads it might improve a little. I'm glad to see some people are building the 318, it is a very overlooked motor. The 411 gears might explain why you are spinning the tires, that's pretty steep for the street. What car do you have this motor in?
http://www.jegs.com/cgi-bin/ncommerc...35&prmenbr=361 these are the heads i'm running.
My current compression is 11.5:1 running 93 octane this is in my mix of a truck...started a 76 dodge d200 (3/4 ton) and put a 51 studebaker pickup body on it... it will run a 12.6 in the quarter right now and boost and nitrous are looking helpful. |
Re: How much power does motor have
Hey, at least I know I'm not insane (at least not yet). You should edit the original post to make it correct...therefore avoiding confusion from others in the future.
What is the cam manufacturer and grind #? What pistons are you using? Last edited by Lonestar; 10-18-2004 at 11:40 PM. |
How did you get 2.02 valves to work on the small bore 318 engine? I heard that too deep of a notch would have to be cut on the top of the cylinder bore for clearence.
so wait, a minute ago you said you hadn't even cleaned the block from the machine shop, and two posts later you're saying its running 12's?
Which is it dood? K |
Lonestar
As for the pistons, they are SRP chrysler flat top pistons: with 60cc combustion chamber they achieve 10.5:1 and the head had .009 taken off to boost it higher. My camshaft is a Mopar Performance "purple shaft". It can be bought at jegs (that is where i bought it.) the grind number, i'm not sure what that is here is the jegs page for it i'm not sure if it will be there or not. http://www.jegs.com/cgi-bin/ncommerc...84&prmenbr=361 Onebadmerc I'm not sure what the machine shop did to make them fit, they built the motor from the block. As far as i know they didn't have to but the might have, i'll ask them sometime this week when i help my friend pick up his B18A4 for his honda. Killerformula I had the machine shop assemble my motor, this included increasing the bore of the motor, this leaves shavings. Read about TurboS10, i've had two motors destroy the main bearings and never thought of why there would be debris there, and yes it was from the same shop both times and so is this motor. And yes it is running a 12.6 but i haven't come close to opening my motor up down the strip yet. I'm still breaking it in, it only has about 5 hours on it.
Am I correct in assuming that you are saying you spent all this money in your engine build...but you don't really know what you have?
12's and you haven't even "come close to opening my motor up down the strip yet." Sorry if I sound skeptical...clue me in. What car, weight, trap speed? What trans, rear end gear ratio? Post some time slips also. Quote:
Lower gears (numerically) have a tendency to spin when hooked to a powerful engine...takes time for the tires to catch up. Last edited by Lonestar; 10-19-2004 at 09:23 PM. |
I'm not sure exactly what some of the parts you are talking about are, my dad picked them out for me, well for the most part, i got to choose between the parts he would recomend. I can tell you aproximate horse power numbers now, i got it back from the dyno.
When i made my 3 runs down the strip. the first one i shifted and stopped at 3500 rpms and that ran a 14.2. With the second i ran it up to 4000 rpms before i stopped that ran a 13.6. And with the third run my motor stalled shifting from 3rd to 4th (about 8 seconds into the run) and that was opening it up to the rev limiter at 8000 rpm shifting from gears. I have 5 gears to go through... the motor will rev to 8000 on command with the best throtle responce out of my chevy and ford, and by far with the most power. The dyno showed that it was pushing 514.6 horsepower and 574.9 ft/lbs of torque. 1951 Studebaker (dodge frame and drive train) it weighes 3256 lbs after i cut off alot of metal that didn't need to be there. Trans i'll have to get back to you on, my dad did everything with it i didn't even get to choose on that. Dana 60 rear end. 4.11 ratio with a Mark Williams light weight spool and hi torque axles. When i go back to my grandparents house in a few weeks i'll get the slips, they live on the other side of wyoming. |
