How much power does my 350 have? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 10:04 PM
chevymastermind's Avatar
drive it like you stole it!
Last journal entry: engine
ok here is the specs.
4 Bolt Main
rare High nickel content block (pretty much un crackable)
9.5:1 compression forged pistons
270* duration Camshaft .454 lift int./exh.
1.94 heads
Edelbrock RPM intake
steal crank
Edelbrock 600CFM carb (soon to be changed to a Holly 670)
K&N airfilter
New headers
duel exhaust with Flowmaster 40 series
No AC or power stearing
Aluminum radiator
im thinking around 300HP-320HP and 380-390 Ft. Lbs. of tourque
help me!!!!!!!!!!!!!
Old 09-26-2006, 10:32 PM
How much power for 350
I don't really know what kind of heads you have but assuming stock heads, I would have to say 275-300 horse.
Old 09-26-2006, 10:47 PM
Jmark's Avatar
It's impossible to give a close estimate. You need to find a dyno and have it tested.
Old 09-27-2006, 06:07 AM
cabowabo's Avatar
big Q
give me some specs
bore and stroke size
cly heads size intake cc ?
int valve size
exh valve size
any porting -stock or polished /race ?
comp ratio
cam shaft type -hyd or hyd roller-roller-solid
int dur
exh dur
int valve lift
exh valve lift
lobe sepertion
cfm size -carb -inj,tpi-tbi-
plenum design -dual-single-t ram -
space height ?
exhaust system-dual-open headers-stock-hi flow dual-race dual
total timming degrees
nitrous -turbo-blower?
electric fuel pump
electric water pump
Old 09-27-2006, 07:35 AM
300hp seems reasonable.
here is a site will over 100 sbc combos dyno'd. Kind of a strange pairing being a sbc dyno and bible website.
http://www.ryanscarpage.50megs.com/
The site shows that stock heads suck. You really need some good aftermarket heads to make hp. You should be making 350 hp with a 350 and a mild cam.
Old 09-27-2006, 02:38 PM
4.030 bore 3.48 stroke
Performer RPM intake
462 Casting 1.94x1.54
9.54:1 CR
Holley 670
1 5/8 headers, 2.5 exhaust
Stock rockers
270/270-.454/.454 cam??
354hp@5250, 387tq@3500
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
350 power 83longchevy Engine 10 10-19-2005 10:39 PM
How much power can a turbo 350 take ratfink14 Transmission - Rearend 4 07-22-2003 09:45 PM
79 Z28 350 / auto with no power brandma Engine 1 07-10-2003 02:28 PM
i need the most horse power for street performance out of a 350 rocket any ideas olds86rocket Hotrodders' Lounge 2 02-19-2003 08:07 PM
