Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much power is my 454 making now? and what mods should be next?
Old 12-14-2011, 11:31 PM
nfreas313 nfreas313 is offline
Originally Posted by 454C10
what gear ratio?
you can change to a thinner head gasket but that will not help much.
To make a differenece, either change to a smaller combustion chamber head or get some pistons with a small dome. 820's heads have 110cc chambers (10cc less than the 781's).
Or, use the 8:1 cr to your advantage and add some force induction (turbos, super charger, blower, or n02).
I am planning on running a 100 shot soon and some forced induction later on down the road so I probably will be ok with the low compression
