Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much power is my 454 making now? and what mods should be next?
  #31 (permalink)
Old 12-16-2011, 09:32 PM
454C10 454C10 is offline
http://www.popularhotrodding.com/tec...ech/index.html
say you had a 425hp engine with 10:1 cr, Then dropped the compression ratio down to 8:1. Then the engine would lose 6.5% power or 27.6hp in this case.
Shortening up the mechanical advance slot and running a lot of initial ignition timing helps low compression engines gain more throttle response. What does your timing curve look like?
