Originally Posted by 454C10
http://www.popularhotrodding.com/tec...ech/index.html
say you had a 425hp engine with 10:1 cr, Then dropped the compression ratio down to 8:1. Then the engine would lose 6.5% power or 27.6hp in this case.
Shortening up the mechanical advance slot and running a lot of initial ignition timing helps low compression engines gain more throttle response. What does your timing curve look like?
Ok so i see that you are saying that if i simply did the work to increase my CR that i would see a hp gain but would i drop a bit it torque? or would i also see a gain there? I am lookin for High torque with moderate hp
