How Much Power Should This Build Make? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2008, 03:49 PM
i have a 350 block out of a 73 z28 camaro
.30 over with hypereutitic flat top pistons
remaned 350 crank and rods
500 lift hydraulic crane cam and lifter set(302 advertised duration/ 246 duration @ 050)
291 double hump heads with 2.02/ 1.6 valves performance springs and self aligning rocker arms
edelbrock performer intake, holley 650 carb, and 65k volt hei distributor
i put this all together for less than a grand as just my first sbc build and was wonderin wut kind of power to be expecting
thanx caleb
Old 09-12-2008, 05:35 PM
you arn't using guideplates are you????
350 horse if you can make it to 6000rpm be my guess
Old 09-12-2008, 07:10 PM
Mez Mez is offline
Given you're name here 87iroc are you putting this motor in this car? If so why 650 holley? Mainly be careful of compression ratios just because a piston says it will net 9.0:1 doesn't mean you will get it. Things should be checked etc when assembled and if needed deck or mill the block or heads to get the desired ratio. I find with cheaper pistons etc that you end up with 8.3:1 instead of the intended 9.0:1 you expected. If a cam is to big and or compression is too low its a bad thing. Also note the price of fuel if you try to push you're comp ration higher like 10:0.1 you will have to run super all the time. Since you said this is you're first build I would ask a lot of questions take you're time and do a lot of research. It's always best to have a realistic goal and a plan on how to get there.
Old 09-12-2008, 08:01 PM
ya theres guide plates on it....should i take them off? and wut carb should i run?
Old 09-13-2008, 12:14 PM
yes take them off you dont run guide plates with self aligning rocker arms use 1 or the other
not to mention you need hardened/chromeolly pushrods with guideplates
Old 09-13-2008, 04:41 PM
im not arguin cuz like i said ive just started getting into sbc's, but y cant i use both? and wuts wrong with a holley 650 carb on it?
Old 09-13-2008, 05:11 PM
bind my friend
apperently anyway ive always listened to manufacturers warnings
one or the other is perfectly fine
dont do both
Old 09-14-2008, 08:11 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
You'll have a pretty insane mismatch with the heads and cam. The cam won't start making power until 4000 rpms, and those heads will be all out of breath by 4800.
In my opinion, WAAAAYY too much cam. You'll be back in a month wondering why your idle is so rich, you can't operate your brakes, and wondering why it has no "oomph." Make sure you have at least 10.5:1 compression (11:1 is better) and a deep wallet to pay for all the 104 octane Also make sure you have the RIGHT valvesprings, not just "performance." At that lift and duration, I would also expect you'll lose some rocker studs.
I think you'll be highly disappointed, but I would guess you should expect 300-325 hp. That cam could easily support 450-500 with the right heads.
Cheap factory smogger heads means cheap factory smogger power. Those heads would be well matched with a cam that is more like 252 advertised/204 duration @ 50. 246 duration is really race-only territory which means race-prepped heads.
Sorry to be the downer, but you get what you pay for and I'm not in the mood for sunshine and BS
Old 09-14-2008, 09:07 PM
ya like i said im a nube with sbc's thats why i made this posting for advice like this. im in no hurry and its not in the car yet so i could always get different heads on it easily.......in your opinion which heads should i look at getting to make this 450-500hp?
Old 09-14-2008, 09:31 PM
techinspector1's Avatar
Wiki Edits: 326
Look at combo 15 here. It lists all the parts to make the power you want, but it's in a 383 stroker motor, not a 350.
http://www.ryanscarpage.50megs.com/combos2.html
If I were you, I wouldn't be expecting much out of the combo you put together. A classic mis-match of parts.
The first thing you want to do if you want 500hp is to call the bank and have the limit increased on your Visa card
Old 09-14-2008, 10:11 PM
that comment was to curtis
Old 09-15-2008, 03:08 AM
Wiki Edits: 326
Well then you need to start off the post with something like "Hey Curtis,....." or "ATTENTION CURTIS" or "Lookin' for an answer from Curtis here" or something similar to that. This is an open forum and most anybody will answer most anything they want to if you don't specify that you want an answer from a specific person. I really didn't think you'd like my answer though, because I didn't tell you what you wanted to hear. It is what it is.
Old 09-15-2008, 06:03 AM
HEY ATTN: CUTRIS73 LOOKING for AN Answer from YOU. which heads do you think i shoulgd get?
Old 09-15-2008, 10:27 AM
attn anybody: instead of messing with new heads what would be the best cam to use with these heads?
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Can you make power with chev 4.3L??? boneyard Buick Engine 1 08-28-2006 05:04 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
How much power will a stock 455 4 barrel make? brian12c Engine 3 03-28-2005 08:39 PM
Accessory Power Failure (1990 Dodge Shadow) arcee123 Electrical 2 12-19-2004 06:41 PM
