How much power should I make?? Dyno people... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2002, 09:40 AM
Post How much power should I make?? Dyno people...
350 2 bolt
Bored .030 over
Stock Crank
Stock 5.7 Rods
.125" Domed Pistons
Fel-Pro Iron Head Gasket. .041 thickness
Heads are 165cc intake, 58cc chamcers, 1.94" intake, 1.50" exhaust, 23 degrees
Cam is 230/230 465/465 lift, 102 Intake, 110 Lobe Seperation
1.5 Ratio Roller Rockers
Holley 750 Double Pumper
Edelbrock Performer RPM w/ Air Gap
1 5/8" Headers
Stock HEI
Anyone have that dyno program that might be able to give me a ballpark figure??
Also, how does that combination look to you?
Old 07-20-2002, 06:42 PM
Tom Tom is offline
Post
combo looks good, I figure it for maybe 325 hp at flywheel
Old 07-22-2002, 05:31 PM
Post
Damn, I was expecting a little more then that. Hmm. Anything you see as holding my engine back?
Old 07-25-2002, 07:39 PM
Post
as for the dyno im still looking for a simpler way not so exspenceve .wanting to do mine. as for engin what rpm you looking for , and what trany you got.
bob
Old 07-26-2002, 04:36 AM
New Member
Post
so its a pretty stock bottom end and thats about 5500rpm, heads sound good -they must be around 64cc-ish witch is good compression medium valves for more tourqe , the cam is perfect from around 2000-6000-ish, roller rockers at 1.5 is good and less ware on valve train,holly 750 is good altho maybe something a little smaller for the street.rpm air gap ...i have one of these ,good alround power,look good to.so the safe max rpm would be 5500 for the bot end and the lowest rpm would be about 2000.....perfect ,coupled with a higher(slightly higher) stall converter wood be great.id go with Tom on the horse power .where were you looking for your power range ?i don't no about the headers ...is the 15/8 taken from the inside dia or the outside ...i've always woundered that ?is it for the street? is it balanced ?is it a go-err?
Old 07-26-2002, 09:45 PM
Post
The power range is exactly where I wanted it to be. 2000-6000 range
Im looking into getting 2800 Stall Converter, Its gonna be a stree/strip truck. Just a toy.
Its going in a 85 GMC S15, 2wd, ext cab truck. TH350 behind the engine.
Old 08-06-2002, 05:59 PM
Post
The headers are 1 5/8" inside diameter.
I should have about 11.5:1 to 12:1 compression. In between there somewhere. I am gonna run racing fuel in it to, so detonation wont start.
