Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much power will this motor make
Old 12-15-2009, 02:14 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Lift is the least needed camshaft spec, we need duration @ .050 and lobe seperation angle to be able to input good data. Also need head flow #'s if you want results to be worth anything.
Holley never made a 780 DP, just 750 or 800 in the Double Pumper line, so what carb do you have?? 780's are Vacuum secondary with dual feed bowls.
