Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much power will this motor make
Old 12-15-2009, 07:37 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Originally Posted by old fords
http://www.summitracing.com/parts/CC...n/?prefilter=1
would that cam be better suited for the engine. I plan to keep it full weight. Probbaly 2900 with driver. If it runs high 6's or low 7's I am satisfied.
That's a big step in the right direction, certainly better than hydro. If you really want to step on it, call Bullet Cams (what used to be Ultradyne) or Mike Jones Cams for a custom grind matched to your requirements. These guys are two of the best in the business. No off the shelf cam will be able to touch a grind from either of thise two companies. I never buy a shelf cam for any engine build for the power you are seeking, custom for the win!!
WWW.jonescams.com
If you want big power, you have to look outside the Summit or Jegs catalogs when it comes to the cam and the carb.
