Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much power will should i make?
Old 04-03-2012, 09:58 AM
Raptorus1 Raptorus1 is offline
[QUOTE=my87Z] the factory dished pistons are what is acutally hurting you since you are acutally loosing power due to there not being a propper quench pad.[QUOTE=my87Z]
Second question is there a design fault in the factor piston? by the calculations i have the quench would be about .065 which within the optimal range of .06-.08 correct me if im wrong.
