how much power would you say - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2010, 02:21 PM
how much power would you say a chevy 400 would make with these specs
bored out .040
KB hyper pistons 9.3 compression 30cc dish
GM vortec 64 cc heads cast iron
Lunati voodoo camshaft Duration @ .050 (Int/Exh): 213/219
Valve Lift (Int/Exh): .454/.468
with a dual plane edelbrock performer intake
HEI distributor
a edelbrock 750cfm carb.
and a set of headers
what are your guyz estimates on power? hp and torque
Old 03-03-2010, 02:27 PM
Banned
370/440 just a wag though.
Old 03-03-2010, 04:31 PM
techinspector1's Avatar
Wiki Edits: 326
Performer RPM will show a 30-40 hp increase over a standard Performer, FWIW.
Old 03-03-2010, 04:39 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i think you may be close, my guestimate would be around 340hp/400tq, i think this motor may benifit from a little larger duration and lift on the cam, plus what Tech1 said with the RPM intake.
Old 03-03-2010, 09:35 PM
thank you guyz for the estimates, the engine is actually used in a truck for some off road stuff and some occational towing a camping trailer that weighs about 7500
Old 03-03-2010, 09:50 PM
30-40hp from just an intake manifold???
Old 03-03-2010, 10:49 PM
Wiki Edits: 326
Yep, the larger runners and straighter shot at the intake ports on the head along with a good set of long tube headers will go a long way toward lettin' the motor breathe.
Old 03-04-2010, 09:20 AM
Wow maybe I should change th gm aluminum manifold on my zz4 before I install it!
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 10:12 AM
chevy 350 jimang22 Engine 4 07-14-2007 04:49 PM
Pully problems: sbc 671 weiand, power steering malibu68 Engine 1 12-05-2006 11:09 AM
Advise on Porta Power choice meanroy Body - Exterior 7 06-24-2004 12:38 AM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
