Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much rear end grease?
Old 08-09-2002, 02:48 PM
axle bastard's Avatar
axle bastard axle bastard is offline
you're killin me buck!
Post
clunking is NOT good. worn bearings can cause excessive backlask that can clunk. excessive backlash can also cause misalignment of the gears causing a whine.
what kinda rear you got in the grem?
if the play is in the pinion yoke/ pinion, that will cause misalignment, giving the clunk and whine.
[ August 09, 2002: Message edited by: axle bastard ]</p>
