Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much should i lower my car to get this stance?? (Pictures)
Old 10-13-2011, 08:04 AM
Tony@AirRideTech Tony@AirRideTech is offline
That car is low... pictures and colors make it look off but if you judge by the wheel centerline and the fact that there really is a little bit of rubber on there, she is down there. I also bet its on Air because it looks like it had a dakota digital control system mounted in the console and you would not want to drive a first gen that low cause you would be sitting on the factory bumpstops unless you cut the pan out.
That is a good looking car and as far as the fender mouldings go... those arent stick on plastic mouldings
