-   -   How much should i lower my car to get this stance?? (Pictures) (http://www.hotrodders.com/forum/how-much-should-i-lower-my-car-get-stance-pictures-206182.html)
darce 09-26-2011 10:56 PM
Hello i got a couple of questions how much should i lower my car from the front to get this stance?? Will the wheel wells need modifing? My car is a 1973 camaro with a SBC. Thanks
[URL=http://www.interiorsbyshannon.com/1967_camaro_exterior.htm]
SSedan64 09-27-2011 01:18 AM
Luckily the 73 2nd Gen has a little more clearance than the 1st Gen F-body does. Mods will depend on Wheel & Tire size wanted.
poncho62 09-27-2011 05:15 AM
Here is your picture
http://www.interiorsbyshannon.com/19...o_exterior.htm
malc 09-27-2011 06:55 AM
Looks to me like itīs on airbags, lowered while parked.
http://www.interiorsbyshannon.com/19...rod_stance.jpg
S10xGN 09-27-2011 08:39 AM
Trust me, you'd be very unhappy actually driving a car that low. Bags are one thing, but leaving it like that and trying drive it...
Russ
prostreet6t9 09-27-2011 08:53 AM
I dont think the car is as low as it looks. Look at the distance at the rockers. I think Thats all wheel and tires.
spc78 09-27-2011 08:54 AM
I agree, that has to be bagged!
Arrowhead 09-27-2011 11:29 AM
X2
Old Foose trick, giant wheels, rubber band tires, instant lowering job.
The car is lowered also though, but probably driveable like that. My Mustang was low but never had a problem.
http://www.hotrodders.com/forum/atta...chmentid=41556
darce 09-27-2011 02:30 PM
ok i guess going to lower it 3 inches from the front and get 18 inch rims with rubberband tires like mentioned. hopefully i get the stance i want.
prostreet6t9 09-27-2011 06:03 PM
If you lower the front your gonna need to lower the rear to level it out.
darce 09-27-2011 06:11 PM
yea i might lower it an inch from the back but am kinda looking for that stance were the front is low and the back is a little higher. Thanks for the input though.
deadbodyman 10-02-2011 01:56 PM
anyone notice the shape of the front wheel well openings and how they look backwards????? oh and the stick on plastic mouldings to cover the hacked wheel wells.....Hmmmmmm.... Git the rope.....
Tony@AirRideTech 10-13-2011 08:04 AM
That car is low... pictures and colors make it look off but if you judge by the wheel centerline and the fact that there really is a little bit of rubber on there, she is down there. I also bet its on Air because it looks like it had a dakota digital control system mounted in the console and you would not want to drive a first gen that low cause you would be sitting on the factory bumpstops unless you cut the pan out.
That is a good looking car and as far as the fender mouldings go... those arent stick on plastic mouldings :D
