How much should i lower my car to get this stance?? (Pictures) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2011, 10:56 PM
Hello i got a couple of questions how much should i lower my car from the front to get this stance?? Will the wheel wells need modifing? My car is a 1973 camaro with a SBC. Thanks
[URL=http://www.interiorsbyshannon.com/1967_camaro_exterior.htm]
Old 09-27-2011, 01:18 AM
SSedan64's Avatar
Luckily the 73 2nd Gen has a little more clearance than the 1st Gen F-body does. Mods will depend on Wheel & Tire size wanted.
Old 09-27-2011, 05:15 AM
poncho62's Avatar
Wiki Edits: 5
Here is your picture
http://www.interiorsbyshannon.com/19...o_exterior.htm
Ontario Rodders
Old 09-27-2011, 06:55 AM
malc's Avatar
Born To Be Mild
Looks to me like itīs on airbags, lowered while parked.
Old 09-27-2011, 08:39 AM
S10xGN's Avatar
Gotta love a turbo!
Trust me, you'd be very unhappy actually driving a car that low. Bags are one thing, but leaving it like that and trying drive it...
Russ
Old 09-27-2011, 08:53 AM
prostreet6t9's Avatar
Differential/Driveline
I dont think the car is as low as it looks. Look at the distance at the rockers. I think Thats all wheel and tires.
Old 09-27-2011, 08:54 AM
spc78's Avatar
I agree, that has to be bagged!
Old 09-27-2011, 11:29 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
X2
Old Foose trick, giant wheels, rubber band tires, instant lowering job.
The car is lowered also though, but probably driveable like that. My Mustang was low but never had a problem.
Old 09-27-2011, 02:30 PM
ok i guess going to lower it 3 inches from the front and get 18 inch rims with rubberband tires like mentioned. hopefully i get the stance i want.
Old 09-27-2011, 06:03 PM
If you lower the front your gonna need to lower the rear to level it out.
Old 09-27-2011, 06:11 PM
yea i might lower it an inch from the back but am kinda looking for that stance were the front is low and the back is a little higher. Thanks for the input though.
Old 10-02-2011, 01:56 PM
deadbodyman's Avatar
Wiki Edits: 11
anyone notice the shape of the front wheel well openings and how they look backwards????? oh and the stick on plastic mouldings to cover the hacked wheel wells.....Hmmmmmm.... Git the rope.....
Old 10-13-2011, 08:04 AM
That car is low... pictures and colors make it look off but if you judge by the wheel centerline and the fact that there really is a little bit of rubber on there, she is down there. I also bet its on Air because it looks like it had a dakota digital control system mounted in the console and you would not want to drive a first gen that low cause you would be sitting on the factory bumpstops unless you cut the pan out.
That is a good looking car and as far as the fender mouldings go... those arent stick on plastic mouldings
Hot rod stance 77bronco_ed Suspension - Brakes - Steering 3 07-27-2011 07:23 PM
chevelle stance winko33 Suspension - Brakes - Steering 0 03-29-2009 10:50 AM
Lower compession = lower octane? Arrowhead Engine 8 11-18-2007 05:45 AM
How much lower will the frame lower once the real motor is installed ? Tonythefish Suspension - Brakes - Steering 3 02-05-2007 04:14 PM
Getting the stance BMM General Rodding Tech 1 09-19-2006 06:18 AM
