How Much should Materials cost? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2005, 04:26 PM
rick458's Avatar
Wookie
I did a search but only found shop prices for paint jobs
77 Impala, I plan on using an Epoxy Primer, Base coat/Clear Coat, minor filler work, Car will be in Primer for a while and be outside.
what is a rough estimate, of the Material cost IE Tape, Epoxy Primer, Base Coat, Catalyzers, ETC... I will need on hand before beginning.
Old 02-26-2005, 05:55 PM
302 Z28's Avatar
$1000 to $1500.
Vince
Old 02-26-2005, 06:58 PM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by 302/Z28
$1000 to $1500.
Vince
Vince, I'm right across the street from you, bud! Look me up sometime, I'll PM you with my number.
BTW, I just bought a gallon of SPI epoxy primer, a gallon of SPI hi-build primer, and 2 gallons of water-based cleaner for $318.00 shipped. Each gallon of SPI will make 2 gallons of sprayable material, so 4 gallons for ~ $250.00 w/o shipping.
Russ
Old 02-26-2005, 09:15 PM
Other guys probably know more, but i just priced stuff for my 76 monte, I'm in the northeast and prices are higher out hear: It looks like a gal of urethane base (dupont) and reducer, was ~$130. All told, w/ epoxy primer, primer, bc/cc, it was around $450. Thats assuming 1.5 gal of base with 1:1 dilution, doing the door jams and all. Hope this helps. - Adam
Old 02-27-2005, 03:48 AM
rick458's Avatar
Wookie
good info Guys thats what I need to know
If I use the SPI Epoxy primer do I need a sealing Primer on top of it before
shooting Base coat and clear coat?
Old 02-27-2005, 09:47 AM
S10xGN's Avatar
Gotta love a turbo!
Go here and read the tech sheets, much easier than me trying to explain what's already been said...
Old 02-27-2005, 10:51 AM
rick458's Avatar
Wookie
Let me see if I got this right
Using Southern Polyurathanes Inc to prime the Car
I would need to strip the car and get an 80 grit finish
Use # 700-1 Wax & Grease remover to prep
Use # 6620-1 Black Epoxy 1:1 with #6700-1 Epoxy Activator
Body filler to satisfaction and if no Bare metal reappers
Use #6315-1 Black High Build Primer 4:1 # 6350-4 Turbo Activator
and #8701-1 Medium Urathane Reducer mixed 4/1/1
then be ready for final sanding and laying a Base coat then Clear coat
Can the urathane reducer clean both the Epoxy and Primer from the gun?
Old 02-27-2005, 11:08 AM
BarryK's Avatar
YES. It will do a better job than lacquer thinner, especially on the epoxy.
Old 02-27-2005, 04:20 PM
rick458's Avatar
Wookie
with the Epoxy and Build primer it will be reasonably weather safe wont it?
Old 02-27-2005, 04:35 PM
BarryK's Avatar
The epoxy is totally water proof, so it will work.
Old 03-01-2005, 05:29 AM
rick458's Avatar
Wookie
Will the Southern PolyUrathanes Epoxy/ build primers be compatable with PPG or other brands Base/Clears?
Also I could not tell from the site what all colors were available from SPI I will be going for a Forest Green shade.
Old 03-01-2005, 05:33 AM
I'm sure you won't have any compatability problems using the SPI stuff, Black surfacer is nice but requires a light colored guide coat which is tougher to see than if you used a lighter colored surfacer with a dark guidecoat. I like using lighter colored surfacers for this reason. JMO, Bob
Old 03-01-2005, 08:24 AM
I emailed barry about colors and right now I think the only colors are red, black, and blue but he plans to expand them, and spi products are compatible with PPG. The info is on the spi site you really just have to go through all the pages.
Old 03-01-2005, 09:46 AM
rick458's Avatar
Wookie
I saw the Viper red and Torch blue etc
but not a full color field
I will hit PPG friday to see whats in store
Old 03-01-2005, 11:58 AM
If you saw the colors on the site those are the only ones right now, he said they are the most popular for rod builders who are spi's biggest customer base. Hopefully more colors soon. The prices are really reasonable, everyone I asked is happy with the products, and the support is excellent from what Ive seen so far.
Low cost Gasser cpprint1 Introduce Yourself 1 12-27-2004 01:56 PM
How much does it cost to have someone put new rings on??? 61ChevyTruck Hotrodding Basics 29 09-04-2004 02:44 PM
Rant: Bosch Plugs Cost me $300.00 Rolm Engine 7 07-22-2004 09:50 PM
On average, how much does it cost to get rust fixed? '54-Hunter Body - Exterior 1 03-07-2003 09:49 PM
cost of a 454 rebuild? ratfink14 Engine 1 12-11-2002 11:05 PM
