How much sprayable material to do a full car? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2010, 08:26 AM
Just finishing getting supplies for my 67 fastback, and now I'm curious if I have enough, although the paint store assured me it's more than enough.
I'll be buying 2 sprayable gallons of SPI epoxy primer.
I have 1 gallon of 2k high build, so sprayable about 1.25gallons I guess.
6 quarts of sprayable Prospray base coat (3 quarts, 1:1 mixing).
2 sprayable quarts for lemans stripes.
And I'll be buying 1 gallon (2 sprayable gallons?) of SPI clear.
The interior, undercarriage, and engine bay are done.
So I need to do jambs, and the exterior, and underneath the hood and decklid.
As I said, they assured me it's more than enough, but now I'm getting worried!
Old 09-29-2010, 08:55 AM
302 Z28's Avatar
The epoxy is probably alright. The high build primer depends on how much work you have to do to get to a paint-able surface. FWIW, never take advice from paint store counter drones. For the most part they are clueless about actual work involved and what works best and what doesn't. I think you may be a little light on your base coat amount. You do not want to get into laying your base down and run out. It is always best to have some left over for future repairs if needed. How many coats of base are you planning on shooting? Figure on a minimum of three to four good coats of base.
Vince
Old 09-29-2010, 08:59 AM
Oh god I hope not. I've heard 2-3 coats with Prospray? So exterior, jambs, and underneath decklid and the hood.
Old 09-29-2010, 10:03 AM
imo 3 coats min with base...even whith colourbuild sealer and black i do 3 coats...depending on your colour could be more
Old 09-29-2010, 10:23 AM
302 Z28's Avatar
I bought two gallons of PPG DBC (4 gallons of reduced) for my 34 project and used every bit but a half gallon of reduced material. Granted I went overboard on the base with 4 to 5 good coats but I was not taking any chances with coverage. With body jambs, doors, hood, and deck lid to do I think you are going to run short on base.
Vince
Old 09-29-2010, 08:24 PM
on the primer yes but it depends what kind of finsh your looking becouse it's 2 to 3 coats of base and the same with clear about 3 coats now if ur looking for a show finsh than u have to put more clear and lots of wet sanding
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
donk or lambo's got nothing on this 406chevycaprice Hotrodders' Lounge 28 01-28-2008 08:09 AM
Sprayable Body Filler robs ss Body - Exterior 10 11-19-2007 06:56 PM
Picking a color Wmarden Body - Exterior 6 10-23-2004 11:13 PM
