how much stall do I need? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-18-2010, 11:11 AM
ericnova72's Avatar
More for Less Racer
Originally Posted by chevydragster83
is a trans temp gauge necessary?
No, but it is a nice thing to have. Often you can spot problems before they do damage if you monitor temp, if it starts running hotter than normal something is likely starting to slip in the trans or something is starting to fail in the converter.
SBC stroker project, small budget jankinnu Engine 63 11-21-2010 10:53 PM
what would be the best stall converter for me? tiresmoke55 Transmission - Rearend 3 08-30-2006 03:42 AM
which stall to use.. Lthompson Transmission - Rearend 6 02-08-2005 03:31 PM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
checking stall on converter Checy_Guy Transmission - Rearend 1 07-21-2004 08:06 AM
