how much stall do I need? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 12:11 PM
chevydragster83's Avatar
Okay, I have a 1983 chevy swb 1500 silverado. a 350 crate engine (260hp crate) I upgraded the heads and cam to RHS Pro action 180cc part number 12318-01. A lunatie bracket master II 230/230 292/292 480 lift cam. edelbrock airgap intake with an edelbrock 750 carb. th350 trans, and 4.10 gears.
I am running a stock torque converter, but need a new one. What stall, size and brand would you recommend?
Thanks,
Larry.
Old 10-19-2010, 12:15 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Somewhere in the 3000-3,500 range. Brand is really just preference. You get what you pay for kinda deal.
Old 10-19-2010, 01:06 PM
would 3600 be too much? I found A pretty good deal on a used TCI 3600
Old 10-19-2010, 01:10 PM
3600 would be fine. You should really be able to light em' up with your setup, tuned properly.
Old 10-19-2010, 07:54 PM
ok the part number on it is 241022. it says recomended for high compression engines. I don't think I'm running any more than maybe 9:5.1. do you think that would be a problem?
Old 10-20-2010, 08:03 AM
It's recommended for high compression or high performance engines. That's what you've built right, a high performance engine?
9.5 is a good for a street motor. You shouldn't have any problems other than keeping your foot off of the gas.
Old 10-20-2010, 08:26 AM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
A 2,800 t 3,000 is plenty with that set up and gears id upgrade to a good after market tranny cooler aswell just to be safe in evryday driving conditions.
Sounds fun.
Old 10-20-2010, 08:39 AM
I hope your truck is not to be used as a truck...
Usage makes a big difference in converter selection.
Old 10-20-2010, 02:51 PM
its barley driven on the street. its mostly a weekend drag truck.
Old 10-21-2010, 09:47 AM
Originally Posted by F-BIRD'88
The converter is a very good choice. To maximize the combo the heads can be installed with a thin shim style head gasket felpro 1094. The cr will be .5 higher than with a .040" gasket. You can even shave the heads a bit to 58cc and then install. Much better with the dished pistons. You want the finished cr as close to 10:1 as practical.
Recurve the distributor. See my many posts on this.
It will go like hell. Some P235-60-15 drag radials will help you hook up.
when you say its a good choice are you talking about the TCI super street fighter I was talking about?
I plan on upgrading the rotating assembly befor too long. Thinking about stroking it.
I have a set of 315/60/15 mickey thompson ET street Radials, but I havn't get to test them on the track yet so idk how well they will hook up
Old 10-21-2010, 12:00 PM
I'm pretty sure he's talking about the TCI stall.
Old 10-21-2010, 12:26 PM
is there alot that can be wrong with a torque converter? asfaar as buying a used one can you pretty much tell if its in good shape by looking it over good?
Old 10-21-2010, 12:30 PM
I like TCI brand.
A 10 inch 3000 stall should be good.
Old 10-21-2010, 12:33 PM
I wouldn't buy used. There no telling what could be in it from the other transmission or from sitting up.
If you're trying to save a little money, Jegs makes an affordable stall in the range you're looking at. 3000 - 3500. It'll more than likely stall to 3500 with your truck.
http://www.jegs.com/i/JEGS/555/60403/10002/-1
Old 10-21-2010, 12:51 PM
yes, installing someone's used converter is like installing someone's used condom.
SBC stroker project, small budget jankinnu Engine 63 11-21-2010 10:53 PM
what would be the best stall converter for me? tiresmoke55 Transmission - Rearend 3 08-30-2006 03:42 AM
which stall to use.. Lthompson Transmission - Rearend 6 02-08-2005 03:31 PM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
checking stall on converter Checy_Guy Transmission - Rearend 1 07-21-2004 08:06 AM
