Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much time do you spend 400/600 sanding?
Old 05-02-2013, 03:13 PM
33Willys77's Avatar
33Willys77 33Willys77 is offline
I usually final block with 180 grit, give it 2 light coats of primer and final sand with 400. If you are putting on a sealer, no need to go any finer than 400, and if its epoxy as a sealer, probably be fine with 320.
