Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much time do you spend 400/600 sanding?
Old 05-02-2013, 08:12 PM
Lizer Lizer is offline
Why did Barry say not to wet sand a poly primer? I don't misunderstand. I am not arguing just trying to learn something here. As long as it is given plenty of time to dry and breath I don't understand what the liability is as long as it is not over bare metal.
John
Would you wet sand body filler? My answer to that question is 'No,' which is why I elected not too. Apparently it's the same answer as Barry's. My fear is the poly primer absorbing too much water and not getting out. I think deadbodyman has actually discussed situations where it lifted when wet sanded. This clearly needs googled. I'd consider spraying 2k over it, blocking and wet sanding that but a concern of Barry's was having too many different substrates on there.
How long is long enough to breathe? After sanding these I'll be sealing in good time and I think it would be devastating to have that moisture trapped in there.
