Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much time do you spend 400/600 sanding?
  #17 (permalink)
Old 05-02-2013, 09:41 PM
Lizer Lizer is offline
Originally Posted by mr4speed View Post
Agree with "no" on wet sanding poly primer and all the reasons you have given. The poly primer I am using now is super porous, would not even consider wet sanding this stuff as it would probably soften it up a bit. And this particular poly must be topcoated with an epoxy or 2K, hence the name its called "base primer".
the huge consensus I've found on the web is 'NO' as well. I can't even believe Evercoat makes the claim that it can be wet sanded.
