Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much time do you spend 400/600 sanding?
  #20 (permalink)
Old 05-02-2013, 10:58 PM
John long John long is offline
Using a squeegee to squeegee away the water is the Holy Grail to wet sanding, be it now or cutting the clear for buffing, it gives you even more control over what you are doing than if you were dry sanding.
R & E Paint Supply. 3M 02037, 500 Grit, Imperial Wet or Dry Sandpaper
Your local paint store will have them.
They are really great. I use them a lot. not just for squeegees but sanding blocks when color sanding on crown areas. I think they are the only thing 3M sells that are cheap.
John
