Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How much time do you spend 400/600 sanding?
  #29 (permalink)
Old 05-04-2013, 08:25 PM
Lizer Lizer is offline
I've been spraying SPI for the last 3 years, and it's the only thing I've ever sprayed (besides the Slick Sand). The Slick Sand is already blocked nearly off with 220. I think it sands like butter once I break through the crust with 120. Your suggestion isn't really any different than what's already been talked about here or what I've discussed with Barry, and it's what I'll be doing. Two coats of epoxy, wet sand to 600. I get little to no peel when I spray the epoxy so it will be easy sanding smooth. This is actually more convenient for me because I can just shoot the panels outside and if I get trash on them it will be sanded out.
