How much time do you spend 400/600 sanding? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-05-2013, 08:38 AM
It lasts a long long time, get some dry you will never go back to spray paint again.
  #32 (permalink)
Old 05-05-2013, 08:55 AM
Irelands child's Avatar
Professionally, I would use the dry stuff, but being an amateur, use SEM guide coat, and purchased really cheap at a swap meet from a guy that always has a bunch. I dislike giving 3m any more of my hard earned dollars then necessary - even for their $$$ tape which doesn't seem as good as it was.
Irelands child
The Following User Says Thank You to Irelands child For This Useful Post:
Lizer (05-05-2013)
  #33 (permalink)
Old 05-05-2013, 09:13 AM
I am with you, I LOATH big corporations and chains believe me, I VERY rarely go into any chain when I have a local store or restaurant to give my money to.
But this 3m guide coat is SOOOOOOOO good, it is SOOOOO much better than spray paint you can't believe it. It covers EVERY square inch you want it, with a very fine dust going in very small scratches, it is well worth the money if you ask me.
There are alternatives, just yesterday at a swap meet I was having a long chat with one of my mentors from 35 years ago, one of my very valued mentors (and I tell him every time I see him) and he told me how he had begun to use soot from the torch for guide coat! He fires it up with just the acy on low and waves the torch on the panel putting soot all over it. He then wipes it all over with a rag and it goes in all the scratches and it's his guide coat. He told me how he found it by mistake after he welded a missed crack and then while sanding the area WHAM there were all the scratches. Never done it but it may be an alternative to the 3M stuff.
I am stubborn as heck when it comes to giving money to someone I don't like, I really respect your opinion on not giving money to 3m, believe me I do, but damn it if it's going to make my job easier and better sometimes I will just bite my lip and do it.
  #34 (permalink)
Old 05-05-2013, 10:02 AM
Does the SEM guidecoat spray in a fan pattern?
  #35 (permalink)
Old 05-05-2013, 10:09 AM
geezer69's Avatar
Die standin' up
Last journal entry: geezer69 nova 63
my buddy uses primer for glide coat. just uses dark over light or the other way around. its cheap and works fine. ive helped him many times and his paint jobs are awesome ! i sure as heck dont know much but he does so i thought id mention it here.
  #36 (permalink)
Yes - or at least the can's I've had did. Ya gotta remember, if the corporate finance guy can save a penny a case, things change
Brian - I've seen that acetylene trick used, but have never tried it - remember with some of us being overly mature, CRS goes hand in hand, so had forgotten.
Irelands child
  #37 (permalink)
Old 05-05-2013, 07:14 PM
Josh, the SEM guide coat is basicaly pigment without filler. I use it regularly and it does work way better than spray paint and/or spray primer because it does not fill your sand paper. The powder very well may be better but the SEM is far better than paint. When I repainted my doors this spring I blocked the SPI black epoxy. I used white spray can laquer for guide coat and was wishing I had a can of light guide coat but my local store only had the black.
You will enjoy it if use it I am sure.
Yes it does have a pattern spray nozzle.
The Following User Says Thank You to John long For This Useful Post:
Lizer (05-05-2013)
Spend more time with your kids, pull the plug deckofficer Off-Topic 12 08-04-2012 12:50 AM
Trying To Build A 400 Sbc That Makes At Least 600 To The Crank. Jtaylor88 Engine 15 07-20-2012 10:04 PM
man cave or shop? do you spend time in your whatever, not working on stuff? matts37chev Hotrodders' Lounge 3 01-21-2012 11:10 AM
More time to spend on hot rod... Lee Hulick Hotrodders' Lounge 4 04-13-2005 01:29 AM
Would you spend another $400 on this rearend? shockers69 Transmission - Rearend 1 07-16-2004 06:59 AM
