how much timing advance does a stock chevy points distributor have built in? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2013, 10:15 AM
curious how much built in vaccum advance the chevy points distributors have? bought a new reman one and put a pertronix flame thrower in it for firewall clearance reasons, i know hei ones have 20 but dont know about the points ones...
Old 06-25-2013, 10:35 AM
The timing advance is stamped on the vacuum advance canister mounting plate. It is usually 12 degrees on GM distributors. That is 24 degrees on the crank damper because the distributor turns 1/2 as fast as the crank.
Old 06-25-2013, 11:38 AM
The stamped number on the mounting plate is a is a ID code number. The common stamp code on 1959-1974 Chevrolet V8 engines is B1. That means the vacuum canister has a total advance of 8 degrees (16 degrees on the crank) at 16"-18" vacuum.
Typically a high performance engine with a radical camshaft that produces low manifold vacuum needs 8 degrees advance at 6"-8" Hg. That is a NAPA Echlin VC1810, GM 88924985 (discontinued), AC Delco D1312C vacuum canister..
Chevy 292 distributor timing fordss Hotrodding Basics 12 09-28-2012 08:49 AM
Chevy 235 distributor points nut- what size? matt167 Engine 1 02-29-2012 07:16 PM
timing advance on a lightly built 350 (300 horsepower) Ocean-Angler Engine 7 09-15-2011 07:42 PM
Chevy points distributor identification abe Engine 2 07-30-2004 01:03 AM
how much mechanical advance does a stock distributor have? smlblcks10 Engine 2 11-21-2003 07:25 AM
