Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much timing at idle for this cam?
Old 10-07-2012, 04:46 PM
Project89's Avatar
Project89 Project89 is offline
Originally Posted by ap72 View Post
32 may be a bit too much, I would guess 28-30 degrees at idle, and 32-34 degrees total.
hmmm i never thought about the possibility of 32* at idle being to much , i will set it to 28-30* at idle and see if it picks up a lil bit.
other then that i pretty much have timing all in by 3k to start
from 1psi to 12 psi im at 25* total and from 13psi to 19 psi im at 22*total above 19 psi im down to 19/20*
under non boost conditions im all in at 3k with 34*
