Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how much timing at idle for this cam?
Old 10-07-2012, 05:13 PM
ap72 ap72 is offline
Banned
Originally Posted by Project89 View Post
thanks converter is a touch to tight, i had a 4l80 in the car with a manual valve body and trans brake and a 3,200 stall converter but second gear started slipping so i pulled it out and reinstalled a stock 700r4 and 2,200 stall converter for now .
cam is slightly oversized for this setup but i knew that when i put it back in, i was willing to trade off some power for a nice grumpy idle
a grumpy idle and turbos... You know that usually doesnt mix well, unless you have larger than normal exhaust housings and a good header, even then its usually race only as it leads to reversion issues.
